Save Customized Report As dialog box
You can use the Save Customized Report As dialog box to save a report after customizing it.
Properties
You can customize and save a report by specifying properties such as the name and description.
Report Name
Displays the name of the report. The original report name is displayed by default. You can modify the report name as per the customization. Report name cannot exceed 255 characters.
Specifies the description of the customization made on the report. Description cannot exceed 150 characters.
Command buttons
The command buttons enable you to perform the following tasks:
Save
Saves the customized report .
Cancel
Cancels the recent changes and closes the Save Customized Report As dialog box.
