Schedule Report dialog box
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
You can schedule the reports to be generated on a recurring basis at a specified frequency from the Schedule Report dialog box. The report is sent by email to one or more users specified in the Schedule Report dialog box.
Properties
You can schedule a report by specifying properties such as the email address of the user, the format of the report, and the frequency at which the report is generated.
Using Existing Schedule
Schedule Name
Displays all the existing schedule names. You can select an existing schedule for your reports from here.
Create New Schedule
Schedule Name
Enables you to enter the schedule name while creating a new schedule.
Recipient Email Address
Specifies the email address of the user to whom you want to send the report. You can specify one or more entries, separated by commas. This is a mandatory field.
Report Format
Specifies the format in which you want to schedule the report. The PDF option is selected by default.
Frequency
Specifies the frequency at which you want to schedule the report. The Hourly option is selected by default.
Command buttons
The command buttons enable you to perform the following tasks:
Schedule
Schedules the report with the saved or updated template and closes the Schedule Report dialog box.
Cancel
Closes the Schedule Report dialog box while displaying a message to save the schedule report template.
