Customizing the Volume Capacity and Utilization report to display the least consumed volumes with thin provisioning disabled
You can customize the Volume Capacity and Utilization report to display volumes based on their volume consumption.
About this task
You can also perform this task by going to the Reports page and clicking Run Report for the appropriate report.
Steps
To remove the grouping by SVM, cluster, or volume, perform the following steps:
Click in the column that needs to be ungrouped.
Click the
icon. -
Select Group > Delete Inner Group.
To sort volumes based on percentage consumed, click in the Used Data % column, and click the
icon. -
To filter volumes with thin provisioning disabled, click in the Thin Provisioned column and open the Filter dialog box by clicking the
icon. -
From the Condition list, select Equal To.
Click Select Values and select No.
Click OK.
