Customizing the Volume Capacity and Utilization report to display volumes with noncompliant configuration
You can customize the Volume Capacity and Utilization report to display volumes that are not compliant with company policies. For example, if you must have deduplication enabled on all volumes, you can create a report listing all volumes where deduplication is disabled.
About this task
You can also perform this task by going to the Reports page and clicking Run Report for the appropriate report.
Steps
To remove the grouping by SVM, cluster, or volume, perform the following steps:
Click in the column that needs to be ungrouped.
Click the
icon. -
Select Group > Delete Inner Group.
Hide all columns except for the Cluster, Storage Virtual Machine, Volume, Deduplication, and Deduplication Space Savings (GB) columns:
Click in the column and click the
icon. -
From the menu, select Column > Hide Column.
To filter volumes that deduplication disabled, click in the Deduplication column and open the Filter dialog box by clicking the
icon. -
From the Condition list, select Equal To.
Click Select Values and select Disabled.
Click OK.
To sort volumes based on deduplication space savings, click in the Deduplication Space Savings (GB) column and click the
icon.
