Editing individual volume health threshold settings
PDF of this doc site
Install Unified Manager
Online Help
Monitor and manage cluster performance
Creating your file...
You can edit the health threshold settings for volume capacity, growth, quota, and space reserve of one or more volumes. When a threshold is crossed, alerts are generated and you receive notifications. These notifications help you to take preventive measures based on the event generated.
Before you begin
You must have the OnCommand Administrator or Storage Administrator role.
About this task
Based on changes to the threshold values, events are generated or obsoleted in the next monitoring cycle.
Note that when Autogrow is enabled on a volume that capacity thresholds are considered breached based on the maximum volume size set by autogrow, not based on the original volume size.
Steps
In the left navigation pane, click Health > Volumes.
In the Health/Volumes inventory page, select one or more volumes and then click Edit Thresholds.
In the Edit Volume Thresholds dialog box, edit the threshold settings of one of the following: capacity, Snapshot copies, qtree quota, growth, or inodes by selecting the appropriate check box and then modifying the settings.
Click Save.
