Considerations for using Chain of Custody verification for 7-Mode SnapLock volumes
You should be aware of the considerations for using Chain of Custody verification for 7-Mode SnapLock volumes.
  • The SnapLock Chain of Custody verification must be performed only if it is a requirement for the transition of SnapLock volumes.
    You can perform the Chain of Custody verification for all or a subset of SnapLock volumes in the project.
  • The SnapLock Chain of Custody verification can take a significant amount of time based on the number of files on the 7-Mode SnapLock volumes.
  • The Chain of Custody verification is supported only for read/write 7-Mode SnapLock volumes
    The Chain of Custody verification is not supported for read-only volumes.
  • The Chain of Custody verification is not supported for SnapLock volumes containing files that have names with non-ASCII characters.
