Restrictions for transitioning 7-Mode volumes
You must be aware of certain restrictions for transitioning 7-Mode volumes. Some of the restrictions are due to features that are not supported in ONTAP. For some restrictions, you can perform a corrective action that enables you to continue with the transition.
Volume types
The following types of volumes are not supported for transition:
Traditional volumes
You can use host-based transition methods to transition traditional volumes.
FlexCache volumes
Volume states
Transition is blocked if any of the 7-Mode volumes selected for the transition are in one of the following states:
Offline
Restricted
Inconsistent (
wafl inconsistent)
Volume with qtrees that belong to a different vFiler unit
You cannot transition volumes with qtrees, where the qtrees are owned by a different vFiler unit than that of the volume. Before transition, you must ensure that each volume and all of its qtrees belong to the same vFiler unit by performing one of the following actions:
Move the qtrees to the vFiler unit that owns the volume.
Delete the qtrees.
Inode to parent pathname translation setting
The inode to parent pathname translations must be enabled on each volume. You can enable the parent to pathname translations by turning off the no_i2p option:
vol options vol_name no_i2p off
You do not have to wait for the i2p scan to finish, and you can continue with the transition preparation.
