Starting data copy for a transition project
Download PDF of this page
You can initiate a data copy from 7-Mode volumes to ONTAP volumes for a baseline transfer. The baseline transfer starts when the data copy schedules configured in a project becomes active. After the baseline transfer is complete, the ONTAP volumes are updated periodically based on the data copy schedule.
You must have run a precheck on the project and resolved all errors.
You must have configured a dedicated, high-bandwidth, low-latency network between the source and destination systems for data transfer.
You can use SnapMirror multipathing to balance the data transfer load between the two paths. -
A data copy schedule must be configured for the session.
If you are transitioning to an existing SVM, the volumes are created during this operation. If you are transitioning to a new SVM, the SVM and its volumes get created during this operation.
SnapMirror relationships are created between 7-Mode and ONTAP volumes.
Start the data copy:
transition start -p project_nameIf the start operation fails and data copy is not started, you must resolve the issues and run the
transition startcommand again.7-Mode Transition Tool>transition start -p project_finance [1/17 ] Project status checks [ Ok ] [2/17 ] Validating 7-Mode system information [ Ok ] [3/17 ] Validating 7-Mode volumes information [ Ok ] [4/17 ] Validating Cluster-Mode system information [ Ok ] [5/17 ] Validating Cluster-Mode volume information [ Ok ] [6/17 ] Validating LIF information [ Notifications ] [7/17 ] WAFL prechecks [ Ok ] [8/17 ] UNIX users and groups prechecks [ Warnings ] [9/17 ] SnapMirror prechecks [ Notifications ] [10/17] NFS prechecks [ Warnings ] [11/17] Networking prechecks [ Notifications ] [12/17] CIFS prechecks [ Warnings ] [13/17] Name services prechecks [ Warnings ] [14/17] SAN prechecks [ Ok ] [15/17] Creating Cluster-Mode volumes [ Ok ] [16/17] Establishing SnapMirror relationships between the 7-Mode and Cluster-Mode volumes [ Ok ] [17/17] Initializing SnapMirror relationships between the 7-Mode and Cluster-Mode volumes [ Ok ] Operation summary: ------------------ The 'start' operation is completed with warnings and notifications. 0 Errors - No action required 22 Warnings - Need your attention! 16 Notifications - Please review 102 Informational messages Do you want to see a detailed report {yes, no} [yes]: 22 Warnings: ------------ 20362: Checking whether 7-Mode UNIX groups' names are in use in the Vserver 'vs2'. [ Warning ] > The following 7-Mode UNIX groups' names are already in use in the Vserver 'vs2'. > AFFECTED-OBJECTS: { daemon } 20372: Checking whether 7-Mode UNIX groups' ids are in use in the Vserver 'vs2'. [ Warning ] > The following 7-Mode UNIX groups' ids are already in use in the Vserver 'vs2'. > AFFECTED-OBJECTS: { daemon }The project moves to the copy-baseline state. After the baseline transfer is completed, the project moves to the copy-update state.
Edit on GitHub
