Preparing the 7-Mode systems and hosts for transition assessment
You must ensure that the 7-Mode systems and hosts meet certain network and protocol requirements for successfully generating an assessment report.
Enable HTTPS on the 7-Mode system:
options httpd.admin.ssl.enable on -
Enable TLS on the 7-Mode system:
options tls.enable onThe best practice is to enable TLS because of the security vulnerabilities in SSLv3. -
Enable SSL and disable SSLv2 and SSLv3 on the 7-Mode system:
Set up and start SSL:
secureadmin setup ssl -
Enable SSL:
options ssl.enable on -
Disable SSLv2 and SSLv3:
options ssl.v2.enable offoptions ssl.v3.enable offThe best practice is to disable SSLv2 and SSLv3 to avoid security vulnerabilities.
Enable SSH on the 7-Mode system:
Set up SSH on the 7-Mode system:
secureadmin setup -f sshThe -f option forces the setup to run even if the SSH server is already configured.
Enable SSH:
secureadmin enable ssh2 -
Enable password authentication on the SSH server:
options ssh.passwd_auth.enable -
Enable SSH access to the host:
options ssh.access
Prepare your Windows host systems:
Enable WMI access.
For more information about enabling WMI access, see the host documentation.
If you have Windows Server 2003, verify that you have installed the Microsoft Fibre Channel Information Tool (fcinfo) package and run the tool once on your Windows host system.
This tool enables you to collect the HBA configuration information of the host.
If the system on which the 7-Mode Transition Tool is run does not belong to a domain, verify the following:
The host system belongs to a domain.
If the host has a local user, and the user name for that user is in the following format:
SystemName\Username
Enable SSH on the Linux or ESXi host.
For more information about enabling SSH, see the host documentation.
Verify that you have installed the latest NetApp Host Utilities software for each host.
For information about downloading and installing the NetApp Host Utilities software, see the NetApp Support Site.
Verify that all the hosts and storage systems can be reached by the Windows system from which the 7-Mode Transition Tool is run.
Related information
