Creating a copy-free transition project
Download PDF of this page
The first step in planning a transition project is to select the source 7-Mode HA pair from which you want to transition the disk shelves, aggregates, volumes, and configurations, and then create a transition project.
The 7-Mode controllers in the HA pair must be running a supported ONTAP version on a platform that is supported for a copy-free transition.
Both controllers in the HA configuration must be healthy.
Select the Copy-Free Transition migration method from the homepage and click Start Planning.
If the controller and cluster required for a new project are not added, you can enter the details in the Enter Device Credentials pane.
Select the source 7-Mode HA pair that you want to transition.
Click Create Project.
In the Project Details window, provide a name for the project.
Select a project group to which the project should be added.
You can either create a new project group or add the project to the default group.
Creating a project group enables you to group and monitor related projects.
Click Save.
The Select Target Cluster screen is displayed.
Edit on GitHub
