ONTAP 7-Mode Transition
Installing or uninstalling the 7-Mode Transition Tool on a Windows system
Contributors netapp-maireadn netapp-ivanad
You can download and install the 7-Mode Transition Tool on a Windows system by using the standard wizard-based installer. However, if you have a previously installed version of the 7-Mode Transition Tool, you need to be aware of certain prerequisites before doing so.
  • If you have a 7-Mode Transition Tool version earlier than 3.0 installed in your system, then you need to uninstall that before installing the latest version.
    You must create a backup of the log files if you choose to retain the log files during uninstallation. The 7-Mode Transition Tool installer installs the tool to the same folder and overwrites the log files the next time you run it.
  • If you have 7-Mode Transition Tool 3.0 or later installed in your system, then the following conditions must be met before installing the latest version of the 7-Mode Transition Tool:
    • All existing copy-based transition projects must either be completed or aborted.
    • All existing copy-free transition projects must either be completed or rollback complete.
