System requirements for installing 7-Mode Transition Tool on Linux
You must ensure that the Linux host has the required configuration to install and run the 7-Mode Transition Tool.
Be sure to consult the current 7-Mode Transition Tool Release Notes for the latest information about supported hosts and known issues.
Hardware requirements
Dual-core x64 processor, 1.0 GHz or more
8 GB RAM
40 GB free disk space
Software requirements
Your Linux system must be running one of the following:
Red Hat Enterprise Linux 5.6
Red Hat Enterprise Linux 6.0
Red Hat Enterprise Linux 7.0 (7-Mode Transition Tool version 3.3.2 and later)
CentOS release 6.4
You can use a Linux virtual machine that meets the required software and hardware requirements to install the 7-Mode Transition Tool.
64-bit Oracle JRE 1.8 update 331
7-zip utility (
rpmforge-release-0.3.6-1.el5.rf.x86_64.rpm)
JRE 1.8 and the 7-zip utility must be installed on the Linux system before configuring the 7-Mode Transition Tool. |
