Installation or uninstallation of the 7-Mode Transition Tool is blocked
When you use the 7-Mode Transition Tool installer or the uninstaller to perform any operation (such as install, repair, reinstall, upgrade, uninstall), the following error message is displayed: Another instance of NetApp 7-Mode Transition Tool Setup or Uninstall is running. Only one instance can run at a time.
Workaround
Before you begin, ensure that there are no open instances or dialog boxes of the 7-Mode Transition Tool. Otherwise, you might have to perform the steps again.
Open Registry by clicking Start.
In Search programs and files, enter
RegEdit. -
When Registry Editor is open, locate the HKEY_LOCAL_MACHINE registry hive.
Expand the HKEY_LOCAL_MACHINE hive by clicking the expand icon to the left of the folder icon.
Continue to expand the registry keys and subkeys until you locate
HKEY_LOCAL_MACHINE\ SOFTWARE \NetApp \7-Mode Transition Tool. -
Click 7-Mode Transition Tool.
Right-click INSTALLATION_STATUS, and select Modify.
Change the value from INSTALLER_RUNNING to INSTALLED, and click OK.
You should now be able to perform any operation using the 7-Mode Transition Tool installer or the uninstaller.
