Modifying the configuration options of the 7-Mode Transition Tool
You can edit the $INSTALL_DIR\etc... file to modify any configuration option that is used by the 7-Mode Transition Tool. This file contains information about all of the configurable options that are necessary for the tool to operate.
The file contains various options; for example, you can specify the port on which the tool service starts, and the port that the tool uses to communicate with the 7-Mode system or cluster.
From the system in which the 7-Mode Transition Tool is installed, open the
$INSTALL_DIR\etc\conf\transition-tool.conffile from the installation directory, and then modify it.Port 8443 or 8088 must be available for the 7-Mode Transition Tool to communicate with the 7-Mode system and cluster. If port 8443 or 8088 is not available or if you want to use a different port, you must change the port specified by the
tool.https.portoption in thetransition-tool.conffile. If port 8088 is not available or if you want to use a different port, you must change the port specified by thetool.http.portoption in thetransition-tool.conffile. -
Restart the 7-Mode Transition Tool service for the new values to take effect:
If your system type is… Do the following… Windows
Click Start > Control Panel > System and Security > Administrative Tools > Services.
Right-click the NetApp 7-Mode Transition Tool service, and then click Stop.
Right-click the NetApp 7-Mode Transition Tool service again, and then click Start.
Linux
Run the following command:
service transition-service restart -
After the 7-Mode Transition Tool service is restarted, add the 7-Mode system and cluster credentials again.
