Configure an AFX storage system SVM
Contributors dmp-netapp
After you create an SVM, you can update the configuration based on your requirements and clients needs.
About this task
There are four access paths to the SVM configuration as reflected in the tabs on the landing page for a specific SVM. These include:
  • Overview
    This provides a quick dashboard overview of the current configuration details related to network interfaces and services, protocols, storage, and protection.
  • Settings
    You can access and update the entire SVM configuration as organized in several areas, such as protocols, services, policies, and security.
  • Replication
    This page provides a list of the current replication relationships defined for the SVM.
  • File system
    You can track the activity and analytics for the SVM
Before you begin
You need to decide which SVM you are interested in displaying and updating.
Steps
  1. In System Manager, select Cluster and then Storage VMs.
  2. Select the desired SVM and then the Settings tab.
  3. Review the configuration options on the page; select and update the settings as desired.
Related information
