Create an AFX storage system SVM
You can create an SVM to provide isolation and improve security. You might do this for different groups or projects within your organization.
When you create an SVM, you must provide a name and configure at least one protocol for client access. After selecting a client protocol, you will be prompted for the networking configuration as well. You can change the SVM configuration as needed after it has been created.
You'll need the following:
A minimum of four IP addresses
Name of an IPspace
In System Manager, select Cluster and then Storage VMs.
Select
Provide a name for the SVM.
Select a protocol for client access and provide the configuration details as appropriate.
Add a network interfaces for the SVM including the IP addresses and subnet mask.
Under Storage VM administration, optionally:
Enable a maximum capacity and select a value
Manage an administrator account for the SVM
Select Save.
