Display the AFX storage system SVMs
You can display the data storage VMs defined in your AFX cluster. Each SVM provides an isolated environment for organizing your data and providing client access.
Steps
In System Manager, select Cluster and then Storage VMs.
Hover over the desired SVM and select
to view the primary administrative options including starting and stopping the SVM. -
Optionally select a specific SVM to view more details including overview, settings, replication, and file system.
Related information
