Manage AFX storage system cluster users and roles
You can define user accounts and roles based on the authentication and authorization services available with AFX.
Each ONTAP user needs to have one role assigned. A role includes privileges and determines what actions the user is able to perform. |
Create an account role
Roles for cluster administrators and storage VM administrators are automatically created when your AFX cluster is set up and initialized. You can create additional user account roles to define specific functions that users assigned to the roles can perform on your cluster.
In System Manager, select Cluster and then Settings.
In the Security section, next to Users and roles, select
Under Roles, select
Provide the name of the role and the attributes.
Select Save.
Create a cluster account
You can create a cluster-level account to use when performing cluster or SVM administration.
In the Security section, select
next to Users and roles. -
Select
. under Users. -
Enter a username and then select the role for the user.
The role should be appropriate for the user. For example, the admin role is able to perform the full range of configuration tasks on your cluster.
Select the user login method and the authentication method; this will typically be Password.
Enter a password for the user.
Select Save.
A new account is created and available for use with your AFX cluster.
