FAQ for AFX storage systems
This FAQ list provides answers to questions you might have about your AFX storage system. It includes concepts and terminology that can be helpful when exploring AFX in more detail or performing advanced administration tasks.
General
ONTAP is a robust and versatile storage platform, known for its comprehensive feature set and adaptability to a wide range of storage requirements. While this flexibility makes it an excellent choice for organizations with diverse workloads, some customers can benefit from a more tailored storage solution optimized for the needs of their specific environment.
To address these specialized needs, some NetApp storage systems offer distinct ONTAP personalities, each of which includes a feature set designed to support the unique customer requirements. An ONTAP personality is typically a combination of hardware and software capabilities and purpose-built to deliver an optimized experience for targeted use cases. NetApp provides three ONTAP personalities:
Unified ONTAP - The Unified ONTAP personality delivers a broad set of data management features, supporting NAS, SAN, and S3 protocols for maximum flexibility. This is the NetApp flagship offering, available on AFF and FAS systems as well as virtualized deployments such as ONTAP Select and Cloud Volumes ONTAP.
AFX - The AFX ONTAP personality provides a disaggregated solution engineered to meet the rigorous requirements of high-performance NAS and S3 workloads, including AI/ML applications. AFX systems deliver specialized capabilities for customers requiring scalable, high-throughput file and object storage.
ASA r2 - The ASA r2 ONTAP personality provides a disaggregated solution designed specifically for SAN-only environments. ASA r2 systems streamline the storage experience for block workloads, providing simplified management and performance optimized for SAN customers.
By offering these distinct ONTAP personalities, NetApp enables organizations to select a storage solution aligned with their operational requirements and application workloads.
No. The personality of your ONTAP storage system is immutable and cannot be changed. For example, you cannot convert or upgrade a FAS or AFF storage system (which run the Unified ONTAP personality) to an AFX storage system.
In System Manager, select Cluster in the left navigation pane and then Overview. You'll see the personality displayed on the page. As an alternative, you can issue the command "system node show" at the CLI. You can also determine the personality of an ONTAP cluster using the REST API; see Your first AFX system REST API call for details.
The AFX storage system was announced at the NetApp Insight conference in October, 2025. AFX supports ONTAP 9.17.1 and later releases. Contact your NetApp sales representative for more details.
The term "disaggregated" can have two different though related meanings with AFX depending on the context.
An important concept to begin with is the decoupling of the compute capability in the controller nodes from the storage shelves. With AFX, the cluster compute and storage components are no longer tightly coupled as they are with FAS and AFF systems, which run the Unified ONTAP personality. Instead they are connected through cluster switches. Each AFX node controller has a complete view of the entire cluster storage pool.
The second related concept with disaggregated storage is that the aggregates and RAID management are removed as administrable entities. A storage abstraction layer within AFX automatically configures and manages the low-level aspects of storage, including the physical disks and RAID groups. This allows the AFX administrator to focus on the high-level storage configuration based on volumes and buckets.
Interoperability
No. You cannot mix system nodes that run different ONTAP personalities in the same cluster. For example, you cannot mix AFX nodes (which run the AFX ONTAP personality) with AFF or FAS nodes (which run the Unified ONTAP personality) in the same cluster.
Yes. AFX storage systems support FlexCache both to and from an AFF or FAS system running the unified ONTAP personality. However, you cannot use FlexCache write-back when FlexGroup Advanced Capacity Balancing is enabled for the same volume. ACB is enabled by default for every volume and so you must first disable it (using the option -granular-data`) before you can enable FlexCache write-back. This same restriction also exists with unified ONTAP.
The SnapMirror version rules for AFX are identical to Unified ONTAP. This means that to replicate from Unified ONTAP, the source system must be within the supported version range. To replicate from AFX, the Unified ONTAP system must be at ONTAP 9.16.1 or later (the earliest release the Advanced Capacity Balancing feature is supported). For FlexCache, the same rules apply for source and destination systems as described in TR-4743.
There are some differences in the support for FlexGroup volumes. A FlexGroup volume on AFX cannot be an origin volume for a FlexCache volume using write-back mode.
No. Only the ONTAP REST API is supported with AFX. Any automation code that uses ZAPI needs to be converted to the REST API for use with AFX.
Advanced concepts
The data protocols supported with AFX include the following:
NFSv3, NFSv4.0, NFSv4.1, NFSv4.2
SMB2.x, SMB3.x
S3
NDMP
No. The data protocols in AFX operate the same way as with AFF and FAS systems.
No. ADP is not used with AFX. Because there are no root aggregates with AFX, the ADP feature is not needed to maximize disk space efficiency.
No. Only switches specifically approved for and provided with the AFX storage platform are supported for the cluster network. Also, these backend switches are dedicated for AFX cluster operations. The client access operations (using NFS, SMB, and S3) should only be performed over the frontend client data network.
The cluster network switches are configured using a NetApp-provided configuration file. Changes to the configuration file are not supported.
All the disks and storage shelves attached to an AFX cluster are part of a Storage Availability Zone (SAZ). Each AFX cluster supports only one SAZ which cannot be shared across AFX clusters (except for SnapMirror replication and FlexCache operations).
Every node has visibility to all the storage in the SAZ. When storage shelves are added to a cluster, ONTAP automatically adds the disks.
When data is allocated, it can be placed on any disk in the SAZ. Once the data is placed, there is no need for it to move. A volume is created based on the underlying data and assigned to a specific node. The volumes can be moved by AFX, typically as part of a balancing process. This affects which node's NVRAM commits the write operations to disk. A volume move changes which node owns the volume but the data itself can remain in place.
AFX includes a feature known as Automated Topology Management (ATM) which responds to system and user object imbalances. The primary objective of ATM is to balance volumes across the AFX cluster. When an imbalance is detected, an internal job is triggered to evenly distribute the data across the active nodes. The data is reallocated using ZCVM which only needs to copy and update the object metadata.
NetApp AFX automatically balances the placement of volumes across all the nodes in a cluster. Beginning with ONTAP 9.18.1, the placement algorithm has been enhanced to consider the performance of the nodes when placing or moving volumes. This results in improved performance balancing across the nodes in the AFX cluster and makes it much less likely that any single node becomes overloaded. Previous AFX releases base the placement on the total number of volumes in the cluster. Every node is assigned the same number of volumes regardless of activity.
With AFF and FAS systems, which run the Unified ONTAP personality, it's possible to relocate a volume nondisruptively from one node or aggregate to another in the cluster. This is performed using a background copy operation with SnapMirror technology. A new destination volume is created at the target destination. Depending on the size of the volume and the utilization of cluster resources, the time it takes for a volume move operation to complete can vary.
With AFX, there are no aggregates. All storage is contained within a single Storage Availability Zone (SAZ) which is accessible by every node in the cluster. As a result, volume moves never need to actually copy the data. Instead, all volume moves are performed with pointer updates among the nodes. This is referred to as a Zero Copy Volume Move (ZCVM) and happens instantaneously because no data is actually copied or moved. This is essentially the same volume move process used with Unified ONTAP without the SnapMirror copy.
In the initial 9.17.1 AFX release, volumes will move only in storage failover recovery scenarios and when nodes are added or removed from the cluster. These moves are controlled only through ONTAP.
Yes. Beginning with ONTAP 9.19.1 P3, AFX storage systems support FabricPool for tiering data to capacity object storage. The AFX implementation has several architectural differences with ONTAP. For example, the cloud tier is attached to the entire cluster (or SAZ) versus individual aggregates; and only ONTAP S3 or StorageGRID buckets can be used. For more information, see Learn about FabricPool for AFX storage systems.
No. AFX does not support mixed drive sizes within a single storage shelf. All the drives within a shelf must be the same size. See NetApp Hardware Universe for complete compatibility information on AFX storage system configurations.
