RTO, RPO, and SLA planning
ONTAP allows you to easily tailor an Oracle database data protection strategy to your business requirements.
These requirements include factors such as the speed of recovery, the maximum permissible data loss, and backup retention needs. The data protection plan must also take into consideration various regulatory requirements for data retention and restoration. Finally, different data recovery scenarios must be considered, ranging from the typical and foreseeable recovery resulting from user or application errors up to disaster recovery scenarios that include the complete loss of a site.
Small changes in data protection and recovery policies can have a significant effect on the overall architecture of storage, backup, and recovery. It is critical to define and document standards before starting design work to avoid complicating a data protection architecture. Unnecessary features or levels of protection lead to unnecessary costs and management overhead, and an initially overlooked requirement can lead a project in the wrong direction or require last-minute design changes.
Recovery time objective
The recovery time objective (RTO) defines the maximum time allowed for the recovery of a service. For example, a human resources database might have an RTO of 24 hours because, although it would be very inconvenient to lose access to this data during the workday, the business can still operate. In contrast, a database supporting the general ledger of a bank would have an RTO measured in minutes or even seconds. An RTO of zero is not possible, because there must be a way to differentiate between an actual service outage and a routine event such as a lost network packet. However, a near-zero RTO is a typical requirement.
Recovery point objective
The recovery point objective (RPO) defines the maximum tolerable data loss. In many cases, the RPO is solely determined by the frequency of snapshots or snapmirror updates.
In some cases, the RPO can be made more aggressive be selectively protecting certain data more frequently. In a database context, the RPO is usually a question of how much log data can be lost in a specific situation. In a typical recovery scenario in which a database is damaged due to a product bug or user error, the RPO should be zero, meaning there should be no data loss. The recovery procedure involves restoring an earlier copy of the database files and then replaying the log files to bring the database state up to the desired point in time. The log files required for this operation should already be in place in the original location.
In unusual scenarios, log data might be lost. For example, an accidental or malicious rm -rf * of database files could result in the deletion of all data. The only option would be to restore from backup, including log files, and some data would inevitably be lost. The only option to improve the RPO in a traditional backup environment would be to perform repeated backups of the log data. This has limitations, however, because of the constant data movement and the difficulty maintaining a backup system as a constantly running service. One of the benefits of advanced storage systems is the ability to protect data from accidental or malicious damage to files and thus deliver a better RPO without data movement.
Disaster recovery
Disaster recovery includes the IT architecture, policies, and procedures required to recover a service in the event of a physical disaster. This can include floods, fire, or person acting with malicious or negligent intent.
Disaster recovery is more than just a set of recovery procedures. It is the complete process of identifying the various risks, defining the data recovery and service continuity requirements, and delivering the right architecture with associated procedures.
When establishing data protection requirements, it is critical to differentiate between typical RPO and RTO requirements and the RPO and RTO requirements needed for disaster recovery. Some applications environments require an RPO of zero and a near-zero RTO for data loss situations ranging from a relatively normal user error right up to a fire that destroys a data center. However, there are cost and administrative consequences for these high levels of protection.
In general, nondisaster data recovery requirements should be strict for two reasons. First, application bugs and user errors that damage data are foreseeable to the point they are almost inevitable. Second, it is not difficult to design a backup strategy that can deliver an RPO of zero and a low RTO as long as the storage system is not destroyed. There is no reason not to address a significant risk that is easily remedied, which is why the RPO and RTO targets for local recovery should be aggressive.
Disaster recovery RTO and RPO requirements vary more widely based on the likelihood of a disaster and the consequences of the associated data loss or disruption to a business. RPO and RTO requirements should be based on the actual business needs and not on general principles. They must account for multiple logical and physical disaster scenarios.
Logical disasters
Logical disasters include data corruption caused by users, application or OS bugs, and software malfunctions. Logical disasters can also include malicious attacks by outside parties with viruses or worms or by exploiting application vulnerabilities. In these cases, the physical infrastructure is undamaged but the underlying data is no longer valid.
An increasingly common type of logical disaster is known as ransomware, in which an attack vector is used to encrypt data. Encryption does not damage the data, but it makes it unavailable until payment is made to a third party. An increasing number of enterprises are being specifically targeted with ransomware hacks. For this threat, NetApp offers tamperproof snapshots where not even the storage administrator can change protected data before the configured expiry date.
Physical disasters
Physical disasters include the failure of components of an infrastructure that exceeds its redundancy capabilities and result in a loss of data or an extended loss of service. For example, RAID protection provides disk-drive redundancy, and the use of HBAs provides FC port and FC cable redundancy. Hardware failures of such components is foreseeable and does not impact availability.
In an enterprise environment, it is generally possible to protect the infrastructure of an entire site with redundant components to the point where the only foreseeable physical disaster scenario is complete loss of the site. Disaster recovery planning then depends on site-to-site replication.
Synchronous and asynchronous data protection
In an ideal world, all data would be synchronously replicated across geographically dispersed sites. Such replication is not always feasible or even possible for several reasons:
Synchronous replication unavoidably increases write latency because all changes must be replicated to both locations before the application/database can proceed with processing. The resulting performance effect is sometimes unacceptable, ruling out the use of synchronous mirroring.
The increased adoption of 100% SSD storage means that additional write latency is more likely to be noticed because performance expectations include hundreds of thousands of IOPS and submillisecond latency. Gaining the full benefits of using 100% SSDs can require revisiting the disaster recovery strategy.
Datasets continue to grow in terms of bytes, creating challenges with ensuring sufficient bandwidth to sustain synchronous replication.
Datasets also grow in terms of complexity, creating challenges with the management of large-scale synchronous replication.
Cloud-based strategies frequently involve greater replication distances and latency, further precluding the use of synchronous mirroring.
NetApp offers solutions that include both synchronous replication for the most exacting data recovery demands and asynchronous solutions that allow for better performance and flexibility. In addition, NetApp technology integrates seamlessly with many third-party replication solutions, such as Oracle DataGuard
Retention Time
The final aspect of a data protection strategy is the data retention time, which can vary dramatically.
A typical requirement is 14 days of nightly backups on the primary site and 90 days of backups stored on a secondary site.
Many customers create standalone quarterly archives stored on different media.
A constantly updated database might have no need for historical data, and backups need only be retained for a few days.
Regulatory requirements might require recoverability to the point of any arbitrary transaction in a 365-day window.
