Oracle databases with SyncMirror
The foundation of Oracle data protection with a MetroCluster system is SyncMirror, a maximum-performance, scale-out synchronous mirroring technology.
Data protection with SyncMirror
At the simplest level, synchronous replication means any change must be made to both sides of mirrored storage before it is acknowledged. For example, if a database is writing a log, or a VMware guest is being patched, a write must never be lost. As a protocol level, the storage system must not acknowledge the write until it has been committed to nonvolatile media on both sites. Only then is it safe to proceed without the risk of data loss.
The use of a synchronous replication technology is the first step in designing and managing a synchronous replication solution. The most important consideration is understanding what could happen during various planned and unplanned failure scenarios. Not all synchronous replication solutions offer the same capabilities. If you need a solution that delivers a recovery point objective (RPO) of zero, meaning zero data loss, all failure scenarios must be considered. In particular, what is the expected result when replication is impossible due to loss of connectivity between sites?
SyncMirror data availability
MetroCluster replication is based on NetApp SyncMirror technology, which is designed to efficiently switch into and out of synchronous mode. This capability meets the requirements of customers who demand synchronous replication, but who also need high availability for their data services. For example, if connectivity to a remote site is severed, it is generally preferable to have the storage system continue operating in a non-replicated state.
Many synchronous replication solutions are only capable of operating in synchronous mode. This type of all-or-nothing replication is sometimes called domino mode. Such storage systems stop serving data rather than allowing the local and remote copies of data to become un-synchronized. If replication is forcibly broken, resynchronization can be extremely time consuming and can leave a customer exposed to complete data loss during the time that mirroring is reestablished.
Not only can SyncMirror seamlessly switch out of synchronous mode if the remote site is unreachable, it can also rapidly resync to an RPO = 0 state when connectivity is restored. The stale copy of data at the remote site can also be preserved in a usable state during resynchronization, which ensures that local and remote copies of data exist at all times.
Where domino mode is required, NetApp offers SnapMirror Synchronous (SM-S). Application-level options also exist, such as Oracle DataGuard or SQL Server Always On Availability Groups. OS-level disk mirroring can be an option. Consult your NetApp or partner account team for additional information and options.
