ONTAP commands
event filter show-summary
Display event filter summary
The event filter show-summary command displays a summary of all the event filters. For more details, use the event filter show command.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-filter-name <text>] - Filter Name (privilege: advanced)
Selects the event filters that match this parameter value.
[-rule-count <integer>] - Number of Rules (privilege: advanced)
[-system-defined {true|false}] - System-Defined Filter (privilege: advanced)
Selects the event filters that match this parameter value. System-defined filters are defined by the system and cannot be modified or deleted.
[-access-control-role <text>] - Access Control Role (privilege: advanced)
Selects the event filters that match this parameter value. The access control role indicates the user role that created the filter and is used to control access to the filter based on RBAC rules. For filters created by 'admin', the access control role is empty (indicated by '-').
The following example displays the event filter summary:
cluster-1::*> event filter show-summary
Filter Name         Rule Count  System-Defined Access Control Role
default-trap-events
                    4           true           -
important-events    3           true           -
no-info-debug-events
                    2           true           -
test_filter         1           false          test_role
4 entries were displayed.
