lun copy cancel
Cancel a LUN copy operation before the new LUN has been created
The lun copy cancel command cancels an ongoing LUN copy operation prior to creation of the new LUN. The command fails if the LUN already exists at the destination path; in that case, use the lun delete command to delete the LUN at the destination path.
All data transfers will be halted.
This is an advanced command because the preferred way to cancel a LUN copy operation is to wait until the new LUN becomes visible, and then use the lun delete command to delete the LUN. |
-vserver <Vserver Name>- Vserver Name (privilege: advanced) -
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path>- Destination Path (privilege: advanced)-
Specifies the path of the new LUN. Examples of correct LUN paths:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1
cluster1::*> lun copy cancel -vserver vs1 -destination-path /vol/vol2/lun2
Cancels the copy operation identified by Vserver vs1 and destination path /vol/vol2/lun2 .
