ONTAP commands
lun igroup unbind
Unbind an existing initiator group from a portset
This command unbinds an initiator group from a portset. When you unbind an initiator group from a portset, all of the initiators in the initiator group have access to all target LUNs on all network interfaces.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-igroup <text> - Igroup Name
Specifies the initiator group that you want to unbind from the portset.
cluster1::> lun igroup unbind -vserver vs1 -igroup ig1
Unbinds the initiator group ig1 from the portset on Vserver vs1.
