ONTAP commands
metrocluster check volume show
Show results of the MetroCluster check for volumes
The metrocluster check volume show command displays the results of volume checks performed by the metrocluster check run command.
The command displays the results of the following volume configuration checks:
  • unmirrored-flexgroups: This check looks for FlexGroup volumes residing on unmirrored aggregates.
  • mixed-flexgroups: This check looks for FlexGroup volumes residing on a mix of mirrored and unmirrored aggregates.
Additional information about the warnings, if any, and recovery steps can be viewed by running the command with the -instance parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
This is the name of the vserver that contains the volume that the check results apply to. If this parameter is specified, only rows matching the specified cluster will be displayed.
[-volume <volume name>] - Volume Name
This is the name of the volume that the check results apply to. If this parameter is specified, only rows matching the specified volume will be displayed.
[-check <MetroCluster Volume Check>] - Type of Check
This is the type of the check performed. If this parameter is specified, only rows with this check will be displayed.
[-result {ok|warning|not-run|not-applicable}] - Result of the Check
This is the result of the check. If this parameter is specified, only rows with this result will be displayed.
[-additional-info <text>,…​] - Additional Information/Recovery Steps
This is additional information about the check. This field has more information and recovery steps for the warning. If this parameter is specified, only rows with this additional info will be displayed.
The following example shows the execution of the command in a MetroCluster configuration:
clusA::*> metrocluster check volume show
Last Checked On: 7/25/2018 10:04:07
Vserver               Volume                   Check                 Result
vs1                   unMirr
                                               unmirrored-volumes    warning
vs2                   vs2UnMirrA
2 entries were displayed.
clusA::*> metrocluster check volume show -instance
Vserver Name: vs1
                          Volume Name: unMirr
                        Type of Check: unmirrored-volumes
                  Result of the Check: warning
Additional Information/Recovery Steps: FlexGroup "unMirr" resides on unmirrored aggregates. Parts of the FlexGroup may not be available after an un-planned switchover.
Vserver Name: vs2
                          Volume Name: vs2UnMirrA
Additional Information/Recovery Steps: FlexGroup "vs2UnMirrA" resides on unmirrored aggregates. Parts of the FlexGroup may not be available after an un-planned switchover.
clusA::>
