network interface service-policy create
Create a new service policy
The network interface service-policy create command creates a new service policy with a list of included services. LIFs can reference this policy to control the list of services that they are able to transport on their network. Services can represent applications accessed by a LIF as well as applications served by this cluster.
-vserver <vserver name>- Vserver-
Use this parameter to specify the name of the Vserver on which the service policy will be created.
 -policy <text>- Policy Name-
Use this parameter to specify the name of service policy to be created.
 [-services <LIF Service Name>,…]- Included Services-
Use this parameter to specify a list of services that should be included in this policy.
 [-allowed-addresses <IP Address/Mask>,…]- Allowed Addresses-
Use this parameter to specify a list of subnet masks for addresses that are allowed to access the services in this policy. Use the value
0.0.0.0/0to represent the wildcard IPv4 address and::/0to represent the wildcard IPv6 address.
The following example shows the creation of a service policy with no initial services.
cluster1::> network interface service-policy create -vserver cluster1 -policy empty
cluster1::> network interface service-policy show -vserver cluster1
Vserver   Policy                     Service: Allowed Addresses
cluster1
          default-intercluster       intercluster-core: 0.0.0.0/0
                                     management-https: 0.0.0.0/0
default-management         management-core: 0.0.0.0/0
                                     management-autosupport: 0.0.0.0/0
                                     management-ssh: 0.0.0.0/0
default-route-announce     management-bgp: 0.0.0.0/0
empty                      -
4 entries were displayed.
The following example shows the creation of a new service policy with a specified service list.
cluster1::> network interface service-policy create -vserver cluster1 -policy custom -services intercluster-core,management-ssh
cluster1
          custom                     intercluster-core: 0.0.0.0/0
empty                      -
5 entries were displayed.
