ONTAP commands
network interface service-policy restore-defaults
Restore default settings to a service policy
The network interface service-policy restore-defaults command restores a built-in service-policy to its original state. The default list of services replaces any customizations that have been applied by an administrator. All included services will be updated to use the default allowed address list.
-vserver <vserver name> - Vserver (privilege: advanced)
Use this parameter to specify the name of the Vserver of the service policy to be restored.
-policy <text> - Policy Name (privilege: advanced)
Use this parameter to specify the name of the service policy to be restored.
The following example shows the restoration of a service policy's default settings.
cluster1::> network interface service-policy show -vserver cluster1
Vserver   Policy                     Service: Allowed Addresses
cluster1
          default-intercluster       intercluster-core: 10.1.0.0/16
                                     management-ssh: 10.1.0.0/16
                                     management-https: 10.1.0.0/16
default-management         management-core: 0.0.0.0/0
                                     management-autosupport: 0.0.0.0/0
                                     management-ssh: 0.0.0.0/0
                                     management-https: 0.0.0.0/0
default-route-announce     management-bgp: 0.0.0.0/0
3 entries were displayed.
cluster1::> network interface service-policy restore-defaults -vserver cluster1 -policy default-intercluster
cluster1
          default-intercluster       intercluster-core: 0.0.0.0/0
