network interface service show
Display available interface services
The `network interface service show ` command displays available services for IP LIFs and the TCP or UDP ports that each service listens on. The ports listed in this table correspond to well-known ports that each service can be expected to open a listening socket. Services that do not listen for ingress connections are presented with an empty port list.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-restrictions ](privilege: advanced) -
The
network interface service show-restrictionscommand displays available services for IP LIFs and usage restrictions for each service. The restrictions determine which LIFs are permitted to use each service and what restrictions the service implies for the LIFs that do use it. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-service <LIF Service Name>]- Service Name-
Selects services that match the specified service name.
 [-ports <integer>,…]- TCP/UDP Port Numbers-
Selects services that contain all IP ports in the specified list.
 [-protocol-ports <text>,…]- Protocol: Port Numbers-
<protocol>:<port>combination. [-vserver-policy <svc_vserver_policy>]- Vserver Restrictions-
Selects services that match a specific vserver restriction.
 [-failover-policy <svc_failover_policy>]- Failover Restrictions-
Selects services that match a specific interface failover restriction.
The following example displays the built-in services.
cluster1::> network interface service show
Service                Protocol:Port
intercluster-core      tcp:11104
                       tcp:11105
management-bgp         tcp:179
2 entries were displayed.
