network options load-balancing modify
Modify load balancing algorithm
This command sets the state of geometric mean algorithm for load balancing
- [-enable {true|false}]- Geometric Mean Algorithm for Load Balancing (privilege: advanced)
Setting this parameter to trueenables the geometric mean algorithm for load balancing. Setting it tofalsedisables the geometric mean algorithm for the cluster.
The following example will enable the geometric mean algorithm for load
      balancing.
      cluster1::> network options load-balancing modify -enable true
The following example will disable the geometric mean algorithm for load
      balancing.
      cluster1::> network options load-balancing modify -enable false
 PDFs
PDFs
