ONTAP commands
network subnet create
Create a new layer 3 subnet
Create a new subnet.
[-ipspace <IPspace>] - IPspace Name
The IPspace to which the new subnet belongs.
-subnet-name <subnet name> - Subnet Name
The name of the subnet to be created. The name of the subnet needs to be unique within the IPspace.
-broadcast-domain <Broadcast Domain> - Broadcast Domain
The broadcast domain to which the new subnet belongs.
-subnet <IP Address/Mask> - Layer 3 Subnet
The address and mask of the subnet.
[-gateway <IP Address>] - Gateway
The gateway of the subnet.
[-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}] - IP Addresses or IP Address Ranges
The IP ranges associated with this subnet.
[-force-update-lif-associations <true>] - Change the subnet association
This command will fail if any service processor interfaces or network interfaces are using the IP addresses in the ranges provided. Using this parameter will associate any manually addressed interfaces with the subnet and will allow the command to succeed.
The following examples create subnets named s1 and s6 in IPspace Default .
cluster1::> network subnet create -ipspace Default -broadcast-domain bd1 -subnet-name s1
    -subnet 192.168.1.0/24 -gateway 192.168.1.1 -ip-ranges "192.168.1.1-192.168.1.100, 192.168.1.112, 192.168.1.145"
cluster1::> network subnet create -ipspace Default -broadcast-domain bd1 -subnet-name s6
    -subnet 3FFE::/64 -gateway 3FFE::1 -ip-ranges "3FFE::10-3FFE::20"
