network test-link start-server
Start server for bandwidth test
The network test-link start-server
command starts the server side of the network test-link
test on the designated node.
Only one server at a time can be running for the network test-link
command on a given node. If the network test-link start-server
command is issued and a server is already running on the node, then the command is ignored, and the existing server continues to run.
The server started is listening on port 5201.
-node {<nodename>|local}
- Node Name (privilege: advanced)-
Use this parameter to specify the node where the server is to be started.
The following example starts a server:
cluster1::*> network test-link start-server -node node1
