ONTAP commands
qos workload show
Display a list of workloads
Shows the current status of workloads on a cluster. Use this command to determine the types of workloads that are currently on a cluster. The types of workloads include: system-defined, preset, and user-defined. The system generates system-defined and preset workloads. You cannot create, modify, or delete these workloads. Also, you can only modify or delete a user-defined workload , but cannot create one
{ [-fields <fieldname>,…​]
| [-instance ] }
[-workload <text>] - Workload Name
If you use this parameter, the command displays the workloads that contain the specified workload name.
[-uuid <UUID>] - Workload UUID (privilege: advanced)
If you use this parameter, the command displays the workloads that contain the specified UUID.
[-class <QoS Configuration Class>] - Workload Class
If you use this parameter, the command displays the workloads that contain the specified class. The Class options include system-defined, preset, and user-defined.
[-wid <integer>] - Workload ID
If you use this parameter, the command displays the workloads that contain the specified internal workload ID.
[-category <text>] - Workload Category
If you use this parameter, the command displays the workloads that contain the specified category. The category options include Scanner and Efficiency.
[-policy-group <text>] - Policy Group Name
If you use this parameter, the command displays the workloads that match the specified policy group name.
[-read-ahead <text>] - Read-ahead Tunables
If you use this parameter, the command displays the workloads that contain the specified read-ahead cache tunable.
[-vserver <vserver name>] - Vserver
If you use this parameter, the command displays the workloads that match the specified Vserver.
[-volume <volume name>] - Volume
If you use this parameter, the command displays the workloads that match the specified volume.
[-qtree <qtree name>] - Qtree Name
If you use this parameter, the command displays the workloads that match the specified Qtree name.
[-lun <text>] - LUN Name
If you use this parameter, the command displays the workloads that match the specified LUN name.
[-file <text>] - File Path
If you use this parameter, the command displays the workloads that match the specified file path.
[-max-throughput <qos_tput>] - Maximum Throughput
Selects the workloads that match this parameter value
A maximum throughput limit specifies the throughput in IOPS that the workload must not exceed.
[-min-throughput <qos_tput>] - Minimum Throughput
A minimum throughput specifies the desired performance level for a workload in IOPS.
[-is-adaptive {true|false}] - Adaptive
If you use this parameter, the command displays only adaptive workloads.
[-is-constituent {true|false}] - Is Constituent Volume
If this parameter is specified, the command displays information only about storage objects that either are or are not constituents of a FlexGroup, depending on the value provided.
cluster1::> qos workload show -class user-defined
Workload       Wid   Policy Group Vserver  Volume   LUN    Qtree  File Path
vs2-wid100     100   pg1          vs2      -        -      -      -
Shows all user-defined workloads and the corresponding storage objects on the "cluster1" cluster.
