ONTAP commands
security anti-ransomware update-package-from-uri
Install the new Anti-ransomware package in the cluster
The security anti-ransomware update-package-from-uri command downloads a new Anti-ransomware package to replace the version installed in all nodes of the cluster.
Use only Anti-ransomware package provided by NetApp support for ONTAP with this command."
To update the Anti-ransomware package, perform the following steps:
  • Download the required Anti-ransomware package file from the NetApp support website.
  • Place the downloaded package file (.tgz) on a local web server that the cluster can access without a password.
  • Execute the security anti-ransomware update-package-from-uri command, passing the Universal Resource Identifier (URI) of the file as a parameter.
Note "The command only needs to be executed once for the entire cluster. It will then download and install the package on each node."
-uri {scheme://(hostname|IPv4 Address|'['IPv6 Address']')…​} - URI of Anti-ransomware package
URI of the new Anti-ransomware package.
The following example installs a new version of the Anti-ransomware to the cluster:
cluster1::> security anti-ransomware update-package-from-uri http://www.example.com/auDev__ontap_arpml_package_v1.0.tgz__440ae2e4-fd8f-4225-9bee-94e2da3f9d8d.tgz
