ONTAP commands
security dynamic-authorization trust-score-component modify
Modify a trust score component
The security dynamic-authorization trust-score-component modify command updates an existing custom trust score component.
-vserver <vserver name> - Vserver
This parameter optionally specifies the Vserver associated with the custom trust score provider component. If this parameter is specified, the setting applies to that Vserver only. If not specified, the cluster Vserver setting is used.
-component <text> - Component Name
The component name.
[-weight <integer>] - Score Weight
An integer giving the raw weight of the component, indicating the importance of the component relative to other components for calculating the trust score. Built-in components have a default weightage of 20.
[-provider-uri {scheme://(hostname|IPv4 Address|'['IPv6 Address']')…​}] - Trust Score Provider URI of Component
The trust score provider URI to obtain the trust score for the component. The response from the URI must be in JSON.
[-max-score <integer>] - Max Trust Score of Component
The maximum score for the component.
[-min-score <integer>] - Min Trust Score of Component
The minimum score for the component.
[-score-field <text>] - Score field to check in JSON response
The field within the JSON response to obtain the trust score.
[-score-type {trust-score|risk-score}] - Score Type
This parameter specifies if the score returned from the component is trust score or risk score. The trust score is in ascending order with a higher score denoting a higher trust level, while the risk score is in descending order. The default value is trust-score .
[-secret-access-key <text>] - Access key for trust score provider
An optional field giving the access key for the trust score provider. This is used to authenticate to the provider.
[-provider-http-headers <text>,…​] - Provider HTTP headers
An optional list of HTTP headers required by the trust score provider.
The following command modifies a dynamic authorization custom component for the Administrative Vserver to change the weightage of the component to 100.
cluster1::> security dynamic-authorization trust-score-component modify -component comp1 -weight 100
