ONTAP commands
security dynamic-authorization user-trust-score reset
Resets trust score of user
The security dynamic-authorization user-trust-score reset command resets the trust score of the specified user.
-vserver <vserver name> - Vserver
Selects the Vserver that match this parameter value.
-username <text> - Username
Reset the trust score for this user.
-component <text> - Component Name
The component for which the user trust score has to be reset.
The example below resets the user trust score.
cluster1::> security dynamic-authorization user-trust-score reset -vserver vs1 -username Tsmith -component authentication_history_policy
