security key-manager external azure rekey-internal
Rekey an internal key of the Vserver
This command rekeys the internal Vserver key hierarchy by changing the top-level internal key encryption key (KEK). Upon successful completion of the command, all keys in the Vserver key hierarchy will be protected by the new top-level KEK.
-vserver <Vserver Name>- Vserver (privilege: advanced)-
This parameter specifies the Vserver for which ONTAP should rekey the SVM KEK.
The following command rekeys the SVM KEK for data Vserver v1.
cluster-1::> security key-manager external azure rekey-internal -vserver v1
