security key-manager external remove-servers
Remove external key management servers
This command removes the key management servers at the given hosts and ports from the given Vserver's external key manager's list of key management servers. If any of the specified key management servers is the sole storage location for any key that is in use by ONTAP, then you are unable to remove the key server. When removing key management servers from the external key manager associated with the admin Vserver, you must run the same command specifying the same set of key servers on the peer cluster. When removing key management servers from a data Vserver, you can run the security key-manager external remove-servers command on the active cluster only as the the command is replicated on the peer cluster. This command is not supported when external key management is not enabled for the given Vserver. Use this command is remove primary key servers. To modify the list of secondary key servers associated with a primary key server, use the security key-manager external modify-server command.
-vserver <vserver name>- Vserver Name-
Use this parameter to specify the Vserver on which the external key manager is to be removed.
 -key-servers <Hostname and Port>,…- External Key Management Servers-
Use this parameter to specify the list of key management servers that you want to remove from the external key manager.
 [-force {true|false}]- Bypass OOQ Check?-
Set this parameter to true to bypass checks for out of quorum nodes.
The following example removes the key management server keyserver1.local, listening on the default port of 5696 and the key management server at IP 10.0.0.20, listening on port of 15696.
cluster-1::*> security key-manager external remove-servers -vserver cluster-1 -key-servers keyserver1.local,10.0.0.20:15696
