ONTAP commands
security key-manager key delete
Delete an existing authentication key
This command removes an authentication key from the configured key management servers on the admin Vserver. The command fails if the given key is currently in use by ONTAP. This command is not supported when external key management is not enabled for the admin Vserver.
-key-id <Hex String> - Authentication Key ID (privilege: advanced)
Use this parameter to specify the key ID of the key that you want to remove.
The following example deletes an authentication key:
cluster-1::*> security key-manager key delete -key-id 000000000000000002000000000001006268333f870860128fbe17d393e5083b0000000000000000
