ONTAP commands
security login external-role-mapping show
Display the external role mapping
This command displays the configured mapping between an external IDP (Identity Provider) role and an ONTAP role.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-external-role <text>] - External Role Name
Selects the external role mapping associated with the name that matches this parameter value.
[-provider {basic|keycloak|auth0|adfs|entra}] - Provider Type
Selects the external role mapping associated with the provider that matches this parameter value.
[-ontap-role <text>] - Ontap Role Name
Selects the external role mapping associated with the ONTAP role that matches this parameter value.
[-comment <text>] - Comment
Selects the external role mapping associated with the comment that matches this parameter value.
[-created <MM/DD/YYYY HH:MM:SS>] - Create Timestamp
Selects the external role mapping associated with the created time that matches this parameter value.
The example below displays information about the external role mapping for the role 'Administrator' from the IDP 'entra'.
cluster1::> security login external-rolemapping show -external-role Testing -provider entra
External Role Name     Provider Type    Ontap Role Name       Comment
Administrator          entra            Custom_role           -
