security login group delete
Delete a group configuration
This command deletes a group.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver associated with the group. If this parameter is specified, the group deletion applies to that specific Vserver only. If not specified, the cluster Vserver setting is used.
-name <text>- Group Name-
The name of the group.
-type <entra>- Group Type-
This parameter specifies the IDP the group originates from.
This command deletes a group named 'Eng_group' for the Vserver 'ontapcluster-1', with the type 'entra'.
cluster1::> security login group delete -name Eng_group -type entra -vserver ontapcluster-1
