security login group modify
Modify a group configuration
This command modifies a user group for the login method.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver with which the group is associated.
-name <text>- Group Name-
The name of the group.
-type <entra>- Group Type-
This parameter specifies the IDP the group originates from.
[-uuid <UUID>]- Group UUID-
Specifies the universally unique identifier of the group.
[-comment <text>]- Comment-
This parameter optionally specifies any comments or notes related to the group.
This command modifies the UUID of the group 'Eng_group' on the Vserver 'ontapcluster-1'.
cluster1::> security login group modify -vserver ontapcluster-1 -name Eng_group -type entra -uuid 2ef26315-1234-4778-9944-cf9e7b945d3d
