security login group role-mapping modify
Modify a role mapping
This command creates a mapping between a group and a role.
-group-id <integer>- Group ID-
The group ID for which the role mapping is being modified. The group ID can be obtained by executing the command 'security login group show'.
-role <text>- Role Name-
The name of the role to which the group is being mapped.
[-comment <text>]- Comment-
This parameter optionally specifies any comments or notes related to the group to role mapping.
This command modifies the comment of the role mapping for the group ID "1" and role "admin" to a comment indicating it's 'Group of admins'.
cluster1::> security login group role-mapping modify -group-id 1 -role admin -comment "Group of admins"
