ONTAP commands
security login group role-mapping show
Display the role mapping
This command displays the configured group to role mappings.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-group-id <integer>] - Group ID
Selects the group role mapping associated with the group ID that matches this parameter value.
[-role <text>] - Role Name
Selects the group role mapping associated with the role name that matches this parameter value.
[-comment <text>] - Comment
Selects the group role mapping associated with the comment that matches this parameter value.
[-scope {svm|cluster}] - Cluster or SVM
Selects the group role mapping associated with the scope that matches this parameter value.
The example below displays the group to role mapping for the group ID 1 and the role "admin".
cluster1::> security login group role-mapping show -group-id 1 -role admin
                    Group ID: 1
                   Role Name: admin
                     Comment: -
              Cluster or SVM: cluster
