ONTAP commands
security webauthn credentials delete
Delete Webauthn Credentials Data
The security webauthn credentials delete command deletes a previously registered FIDO2/WebAuthn credential. All users can delete their own registered FIDO2/WebAuthn credentials, regardless of their authorization role. Only users with admin privileges can delete FIDO2/WebAuthn credentials belonging to other users.
-vserver <vserver name> - Vserver
This parameter optionally specifies the Vserver associated with the FIDO2/WebAuthn credential. If not specified, this defaults to the cluster Vserver.
-username <text> - Username
Name of the user whose credential is to be deleted.
-index <integer> - Index
The index of the FIDO2/WebAuthn credential to be deleted. This is used to identify the specific credential if the user has multiple FIDO2/WebAuthn credentials registered and only one of them is to be deleted.
-rpId <text> - Relying Party ID
The rpId of the FIDO2/WebAuthn credential to be deleted.
The following command, when executed by a user with admin privileges, deletes all registered FIDO2/WebAuthn credentials for the Administrative Vserver. When executed by users without admin privileges, the command only deletes that user's own registered credentials:
cluster1::> security webauthn credentials delete *
4 entries were deleted.
The following command, when executed by a user with admin privileges, deletes all registered FIDO2/WebAuthn credentials for the Administrative Vserver for the username user1 :
cluster1::> security webauthn credentials delete -username user1 *
1 entry was deleted.
The following command, when executed by a user with admin privileges, deletes the registered FIDO2/WebAuthn credentials for the Administrative Vserver for the username user1 at index 1 for the rpId myontap.example.com :
cluster1::> security webauthn credentials delete -username user1 -index 1 -rpId myontap.example.com
