ONTAP commands
snaplock log create
Create audit log configuration for a Vserver.
The `snaplock log create` command is used to create a SnapLock log configuration for the Vserver. A SnapLock log configuration consists of volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained.
-vserver <vserver name> - Vserver Name
Specifies the name of the Vserver for which the configuration needs to be created.
-volume <volume name> - Log Volume Name
Specifies the name of the volume that is used for logging. This must be a SnapLock Compliance volume.
[-max-log-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum Size of Log File
Specifies the maximum size of the log file. Once a log file reaches this limit, it is archived and a new log file is created. This parameter is optional. The default value is 10MB .
[-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Default Log Record Retention Period
Specifies the default period of time a record (which is logged) is retained. This parameter is optional. The default value is "6 months" .
cluster1::> snaplock log create -volume vol1 -max-log-size 50MB -default-retention-period "1 year" -vserver vs1
        [Job 47] Job succeeded: SnapLock log created for Vserver "vs1".
