ONTAP commands
statistics oncrpc show-rpc-calls
Display ONC RPC Call Statistics
Note This command is deprecated and will be removed in a future major release.
The statistics oncrpc show-rpc-calls command displays information about the Open Network Computing Remote Procedure Call (ONC RPC) calls performed by the nodes of a cluster.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display information only about the RPC calls performed by the node you specify.
[-protocol {TCP|UDP|RDMA}] - Transport Protocol (privilege: advanced)
Use this parameter to display information only about the RPC calls performed using the network protocol you specify.
[-badproc <Counter with Delta>] - Bad Procedure Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the number of bad procedure calls you specify. Bad procedure calls are RPC requests that contain invalid procedure numbers and cannot be completed.
[-badlen <Counter with Delta>] - Bad Length Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the number of bad length calls you specify.
[-badhdr <Counter with Delta>] - Bad Header Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the number of bad header calls you specify.
[-badcalls <Counter with Delta>] - Bad Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the number of bad calls you specify.
[-badprogcalls <Counter with Delta>] - Bad Program Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the number of bad program calls you specify.
[-calls <Counter64 with Delta>] - Total Calls (privilege: advanced)
Use this parameter to display information only about the RPC calls that have the total number of bad calls you specify.
cluster1::> statistics oncrpc show-rpc-calls
Node               Value              Delta
node1           ------------tcp-------------
Bad Proc:                    0             -
Bad Len:                     0             -
Bad Hdr:                     0             -
Bad Calls:                   0             -
Bad Prog Calls:              0             -
Total Calls:                 0             -
Node               Value              Delta
node1           ------------udp-------------
Bad Proc:                    0             -
Bad Len:                     0             -
Bad Hdr:                     0             -
Bad Calls:                   0             -
Bad Prog Calls:              0             -
Total Calls:                 0             -
Node               Value              Delta
node2           ------------tcp-------------
Bad Proc:                    0             -
Bad Len:                     0             -
Bad Hdr:                     0             -
Bad Calls:                   0             -
Bad Prog Calls:              0             -
Total Calls:                 0             -
Node               Value              Delta
node2           ------------udp-------------
Bad Proc:                    0             -
Bad Len:                     0             -
Bad Hdr:                     0             -
Bad Calls:                   0             -
Bad Prog Calls:              0             -
Total Calls:                 0             -
4 entries were displayed.
