statistics preset delete
Delete an existing Performance Preset
Deletes a performance preset configuration and all of its associated details.
-preset <text>- Preset Name (privilege: advanced)-
Specifies the name of the performance presets that you want to delete.
cluster1::*> statistics preset show
Preset Name: asup-event
Preset UUID: 55c03699-01db-11e2-8e3e-123478563412
Comment: The event-based AutoSupport Data ONTAP Performance Archive
preset configuration. This preset configuration is used
whenever an event-based AutoSupport is triggered.
Privilege: diagnostic
Read-Only: true
Archive Enabled: false
Generation ID: 0
Preset Name: asup-hourly
Preset UUID: 56178a2a-01db-11e2-8e3e-123478563412
Comment: The hourly AutoSupport Data ONTAP Performance Archive
preset configuration. This preset configuration is used by
the hourly AutoSupport collection events.
Read-Only: true
Archive Enabled: true
Generation ID: 0
Preset Name: default
Preset UUID: 55ac6297-01db-11e2-8e3e-123478563412
Comment: The default Data ONTAP Performance Archive preset
configuration. This preset configuration includes
essential counters to assist in general troubleshooting of
system performance.
Read-Only: true
Generation ID: 0
Preset Name: diagnostic
Preset UUID: 561db291-01db-11e2-8e3e-123478563412
Comment: The diagnostic Data ONTAP Performance Archive preset
configuration. This preset configuration includes more
counters at faster sample periods than the default
configuration to assist in troubleshooting abnormal
system performance.
Read-Only: true
Generation ID: 0
Preset Name: foo
Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412
Comment: Test preset
Read-Only: false
Generation ID: 0
5 entries were displayed.
cluster1::*> statistics preset delete -preset foo
Read-Only: true
Generation ID: 0
Read-Only: true
Generation ID: 0
system performance.
Read-Only: true
Generation ID: 0
system performance.
Read-Only: true
Generation ID: 0
4 entries were displayed.
