ONTAP commands
statistics-v1 protocol-request-size show
Display size statistics for CIFS and NFS protocol read and write requests
This command displays size statistics for CIFS and NFS protocol read and write requests. The output of the command includes the following information:
  • Node name
  • Statistic type
  • Average size of request
  • Total request count
  • Current number of requests in each category of request size
  • Number of requests after the command was last executed
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, the command displays statistics only for the specified node.
[-stat-type <Protocol Type>] - RW Request Stat Type
If this parameter is specified, the command displays only the statistics of the specified protocol type. Protocol types include the following: cifs_read, cifs_write, nfs2_read, nfs2_write, nfs3_read, and nfs3_write.
[-total-req-count <Counter64 with Delta>] - Total Request Count
If this parameter is specified, the command displays only statistics with the specified total number of requests.
[-average-size <Counter64 with Delta>] - Average Request Size
If this parameter is specified, the command displays only statistics with the specified average request size.
[-histo08 <Counter64 with Delta>] - 0 - 511
If this parameter is specified, the command displays only statistics with the specified number of requests in this size range.
[-histo09 <Counter64 with Delta>] - 512 - 1023
[-histo10 <Counter64 with Delta>] - 1024 - 2047
[-histo11 <Counter64 with Delta>] - 2048 - 4096
[-histo12 <Counter64 with Delta>] - 4096 - 8191
[-histo13 <Counter64 with Delta>] - 8192 - 16K
[-histo14 <Counter64 with Delta>] - 16K - 32K
[-histo15 <Counter64 with Delta>] - 32K - 64K
[-histo16 <Counter64 with Delta>] - 64K - 128K
[-histo17 <Counter64 with Delta>] - Greater than 128K
The following example displays the number of NFS v3 requests in each size range for only one node in the cluster.
cluster1::> statistics protocol-request-size show -stat-type nfs3_* -node node0
Node:                    node0
Stat Type:               nfs3_read
                         Value       Delta
Average Size:                   6             -
Total Request Count:
                        465947409             -
0-511:                     567023             -
512-1023:                    4306             -
1K-2047:                      175             -
2K-4095:                   160404             -
4K-8191:                   537576             -
8K-16383:                 1742701             -
16K-32767:                1418620             -
32K-65535:
                        461516604             -
64K-131071:                     0             -
128K - :                        0             -
Node:                    node0
Stat Type:               nfs3_write
                         Value       Delta
Average Size:                   0             -
                        199294247             -
0-511:                      36556             -
512-1023:                    3683             -
1K-2047:                      745             -
2K-4095:                     1413             -
4K-8191:                    28643             -
8K-16383:
                        199223207             -
16K-32767:                      0             -
32K-65535:                      0             -
64K-131071:                     0             -
128K - :                        0             -
