storage automated-working-set-analyzer show
Display running instances
The automated-working-set-analyzer show command displays the Automated Working-set Analyzer running instances.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node Name (privilege: advanced)-
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}]- Flash Cache Node-wide Modeling (privilege: advanced)-
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate-uuid <UUID>]- Uuid of the Aggregate (privilege: advanced)-
This parameter indicates the aggregate uuid that the AWA instance runs on.
[-aggregate <aggregate name>]- Aggregate (privilege: advanced)-
This parameter indicates the aggregate name that the AWA instance runs on.
[-working-set-size {true|false}]- Working Set Size (privilege: advanced)-
This parameter indicates whether the AWA instance is configured to find the working set size.
[-start-time <Date>]- Starting Time (privilege: advanced)-
This parameter indicates the time when the AWA instance was started.
[-total-intervals <integer>]- Total Interval Count (privilege: advanced)-
This parameter indicates the total number of intervals that the AWA instance has covered.
[-read-throughput {<integer>[Bps|KBps|MBps|GBps]}]- Read Throughput (privilege: advanced)-
This parameter indicates the maximum read throughput over an interval that AWA has observed from the storage disks.
[-write-throughput {<integer>[Bps|KBps|MBps|GBps]}]- Write Throughput (privilege: advanced)-
This parameter indicates the maximum write throughput over an interval that AWA has observed to the storage disks
[-cacheable-read <percent>]- Cacheable Read (privilege: advanced)-
This parameter indicates the maximum percent of cacheable read over an interval that AWA has observed. Cacheable reads are non-sequential reads, i.e., the percentage of data reads that could have been cached.
[-cacheable-write <percent>]- Cacheable Write (privilege: advanced)-
This parameter indicates the maximum percent of cacheable write over an interval that AWA has observed. Cacheable writes are random overwrites, percentage of disk writes that could have been cached.
[-projected-cache-size {<integer>[KB|MB|GB|TB|PB]}]- Max Projected Cache Size (privilege: advanced)-
This parameter indicates the projected Flash Pool cache usage.
[-projected-read-hit <percent>]- Projected Read Hit (privilege: advanced)-
This parameter indicates the percentage of blocks that could be read from the Flash Pool cache instead of HDDs.
[-projected-write-hit <percent>]- Projected Write Hit (privilege: advanced)-
This parameter indicates the percentage of block overwrites that could go to the Flash Pool cache instead of HDDs.
[-referenced-interval-id <integer>]- Referenced Interval ID (privilege: advanced)-
This parameter indicates the interval in which the cache size effect information is derived from.
[-referenced-interval-time <Date>]- Referenced Interval Time (privilege: advanced)-
This parameter indicates the time when the referenced interval for the cache size effect information is derived from.
[-referenced-interval-cache-size {<integer>[KB|MB|GB|TB|PB]}]- Referenced Interval Cache Size (privilege: advanced)-
This parameter indicates the cache size at the end of the referenced interval from which the cache size effect information is based on.
[-read-hit-20 <percent>]- 20% Cache Read Hit (privilege: advanced)-
This parameter indicates the predicted read hit rate when the cache size is 20% of the referenced cache size.
[-read-hit-40 <percent>]- 40% Cache Read Hit (privilege: advanced)-
This parameter indicates the predicted read hit rate when the cache size is 40% of the referenced cache size.
[-read-hit-60 <percent>]- 60% Cache Read Hit (privilege: advanced)-
This parameter indicates the predicted read hit rate when the cache size is 60% of the referenced cache size.
[-read-hit-80 <percent>]- 80% Cache Read Hit (privilege: advanced)-
This parameter indicates the predicted read hit rate when the cache size is 80% of the referenced cache size.
[-read-hit-100 <percent>]- 100% Cache Read Hit (privilege: advanced)-
This parameter indicates the predicted read hit rate when the cache size is 100% of the referenced cache size.
[-write-hit-20 <percent>]- 20% Cache Write Hit (privilege: advanced)-
This parameter indicates the predicted write hit rate when the cache size is 20% of the referenced cache size.
[-write-hit-40 <percent>]- 40% Cache Write Hit (privilege: advanced)-
This parameter indicates the predicted writehit rate when the cache size is 40% of the referenced cache size.
[-write-hit-60 <percent>]- 60% Cache Write Hit (privilege: advanced)-
This parameter indicates the predicted write hit rate when the cache size is 60% of the referenced cache size.
[-write-hit-80 <percent>]- 80% Cache Write Hit (privilege: advanced)-
This parameter indicates the predicted write hit rate when the cache size is 80% of the referenced cache size.
[-write-hit-100 <percent>]- 100% Cache Write Hit (privilege: advanced)-
This parameter indicates the predicted write hit rate when the cache size is 100% of the referenced cache size.
[-num-intervals-show <integer>]- Number of intervals to show (privilege: advanced)-
This parameter indicates the number of intervals to the past this command is showing.
The following example shows a running instance of automated-working-set-analyzer on node node1 for aggregate aggr0 .
cluster1::> cluster-1::*> storage automated-working-set-analyzer show Node FC Aggregate wss Intervals Start Time -------------- ----- ------------ ------ --------- ------------------------ node1 false aggr0 false 125 Wed Jul 22 13:58:17 2015
