ONTAP commands
storage iscsi-initiator remove-target
Remove an iSCSI target
The storage iscsi-initiator remove-target command removes an iSCSI target from a node's list of targets. This command is only supported on high-availability shared-nothing virtualized platforms.
-node {<nodename>|local} - Node (privilege: advanced)
Specifies the name of the ONTAP node from which the iSCSI target will be removed.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}] - Target Type (privilege: advanced)
Selects targets with the specified target type.
-label <text> - User Defined Identifier (privilege: advanced)
Specifies the label of the target to be removed.
The following example adds and connects to an iSCSI target from the specified node .
cluster1::*> storage iscsi-initiator remove-target -node node1
             -label target1
